What is hybrid monitoring?
Cloud-first and fully cloud strategies have been the main choice for many IT administrators in the last decade. Lately, a more moderate approach has taken the stage. A hybrid infrastructure, mixing cloud and on-premises assets, is increasingly seen as a better option by many companies, for a series of sound reasons.
Mounting public cloud costs, data privacy limitations, and increased complexity have led administrators to juggle assets and services across multiple platforms: public and private clouds, as well as the good old on-premises. Inevitably, this has influenced the way infrastructures are monitored.
Hybrid cloud monitoring presents its own set of challenges and advantages, which we will be exploring in this article. As often we do, an excursus on the exact nomenclature we will be using throughout the article is necessary to avoid confusion and make things clear from the beginning.
TL;DR:
Hybrid monitoring enables organizations to effectively manage their IT infrastructures that blend cloud and on-premises resources, enhancing visibility, security, and cost efficiency.
  • It brings together the monitoring of multi-cloud services and local systems, providing a unified view of metrics across all environments.
  • Successful hybrid monitoring begins in the design phase, emphasizes essential metrics, and leverages automation to minimize manual tasks.
  • Checkmk streamlines management with features like automatic host registration (for both local and cloud), push monitoring agents, and fully customizable dashboards.
What is the difference between hybrid cloud monitoring and multi cloud monitoring?
Hybrid cloud monitoring, or the equivalent hybrid cloud monitoring, is the set of processes and systems that are apt to monitor hybrid infrastructures. Hybrid monitoring is another synonym for hybrid cloud monitoring.
What is not a synonym is multi cloud monitoring. This is a narrower term that refers to the capability of monitoring tools to monitor services and assets across multiple cloud providers.
Hybrid monitoring most definitely includes multi cloud monitoring capabilities.
hybrid monitoring
Challenges of multi cloud and hybrid monitoring
While moving to a hybrid infrastructure is increasingly common, some difficulties have to be addressed.
Limited visibility
A key issue in managing and monitoring hybrid infrastructures is achieving complete end-to-end visibility into software and hardware stacks that are deployed across multiple clouds and on-premises. The fewer cloud services you have, the easier it is to find a complete hybrid IT monitoring solution, but that’s of course limiting. It is unfortunately more common to miss a few cloud services here and there, or have them with a limited set of monitored metrics, and having to rely on cloud-own monitoring solutions like AWS CloudWatch or Azure Monitor, to integrate your tools on locale.
The difficulty in discovering, creating, and maintaining a network topology in hybrid monitoring is a real problem. Obviously increasing cloud observability is a key objective of any hybrid cloud monitoring software but achieving it today in full is not as simple as one would wish to.
Discrepancies between metrics
A hybrid infrastructure often relies on multi cloud assets and services, spread across different vendors, public or private. While this is an advantage in choice and flexibility, it can bite you back when you need to consolidate all the metrics you receive from different APIs and services into a unified view. There is some overlap between the metrics of each tool, while some metrics are unique to a tool.
This would require a separate tool that could integrate all cloud vendors as well as all on-premises software, and provide a meaningful and usable view of all the different metrics and data. Far from an easy task for any company, and a main challenge of hybrid cloud monitoring.
Security
Consigning part of your infrastructure to an external actor is a matter of trust. As the stack grows, so does the attack surface. While it is undoubtable that cloud vendors pay high attention to security, there is more data that moves across networks between your on-premises and your cloud assets. More is exposed, and more can go wrong. Physical security measures become impossible once you have a hybrid infrastructure.
Cloud security requires a different approach to user permissions, data encryption, and secrets management. This reflects on monitoring, where what was once all on your hands becomes a game of managing sensitive data that are partly fully controlled by you and partly on the hands of the cloud vendors.
Costs management
In hybrid cloud monitoring solutions, it is common to find features that can monitor the costs involved in using cloud resources. Rightfully so. While the initial costs are minimal at the start, they can exponentially grow as the volume of used resources grows large.
Hybrid cloud monitoring necessarily includes keeping track of resource utilization across all types of assets and their multiple locations. Correctly setting up a hybrid monitoring solution means being able to set up alerts and notifications for each usage threshold that may incur you in high cost increases. And that is far from trivial, with the sheer number of resources that need to be kept track of to avoid expensive monthly bills.
Best practices in hybrid monitoring
These challenges are not easy to face and the holy grail of a single, unified, and complete view in hybrid cloud monitoring may not be achievable yet. Nonetheless, following a few best practices can make monitoring hybrid infrastructure simpler and more effective.
Hybrid monitoring starts at the design stage
Cloud observability and then hybrid monitoring are hard efforts that become much harder if implemented later than the design stage. Make sure you include monitoring considerations right from the start, when your hybrid infrastructure is being modeled. Security and operations teams both need to have a word on how to design your mix of cloud and on-premises assets to later be able to effectively monitor it all.
Be selective
In hybrid IT monitoring, metrics are surely not lacking. There is a wealth of different ones, coming from a large range of services, from multiple vendors. Just aggregating them all is wasteful, in both resources and costs.
It pays to be more selective. Focus on the main objectives first, whether they may be availability, reliability, performance or others. Then, depending on what you need to monitor, select first the metrics that best inform you about these objectives. It is not about excluding all others, though, but focusing more on what most matters to you first.
Integrate and automate
A hybrid infrastructure is too vast to be handled manually, or even to be only marginally automated. Automation must be a focus in your hybrid cloud monitoring efforts. Modern monitoring tools have ample automation capabilities. Exploiting them is a key practice when dealing with the vastness of a multi cloud or hybrid infrastructure.
Moreover, standardizing backend monitoring procedures and processes help in making hybrid cloud monitoring as seamless as possible. Obtaining maximum hybrid cloud observability goes through aggregating the useful subsets of monitoring data from all the various platforms into a single monitoring system. Integrating centrally all the alerts and notifications, and automating them, becomes exponentially simpler when you have a robust hybrid monitoring setup, not one scattered across multiple tools.
Pay attention to the distribution of the hybrid infrastructure
Multi cloud setups may be the best choice when you are aiming to use the best tools for the job, no matter where they are and, probably, the costs and complexity. Others may prefer to consolidate your cloud services on a single cloud, with tighter integration and easier interoperability.
While the choice depends on your aims and needs, multi cloud monitoring would benefit from having as few vendors as possible without sacrificing features and performance. When you are setting up your hybrid cloud monitoring solution, do pay attention to how the workloads would be best served, across many clouds or close together on a single one. It may be worth making hybrid cloud monitoring more complex in certain circumstances to pick the best services and features.
Choose the best tool for the job
Cloud observability takes some effort, and good planning. Having at hand a good tool for the job is essential. Multi cloud and hybrid monitoring require a solution that covers as many cloud providers and their services as humanly possible, without forgetting the base of bare metal servers and on-premises assets.
A mature, and highly-configurable, alert and notification system is critical to be rapidly informed of anything. In the constant flux that is the world of hybrid cloud monitoring, a tool that can follow it all is beyond just useful, but vital.
Monitoring the always fluctuating, and differing from provider to provider, cloud costs is a basic feature that can save many companies’ observability budgets.
Checkmk was born as a strong monitoring tool for on-premises, but after the 2.2 release it is a full hybrid cloud monitoring software. Auto-registration of local and cloud hosts, push monitoring agents, managing the full host life cycle, backups to the cloud and an expansion of the support for devices and services are only a part of the added features. With an eye to the cloud costs and the as always customizable dashboards, Checkmk can make the life of administrators of hybrid infrastructures noticeably easier.
